im trying to figure out how i can tell if the injectors i have are original to the engine or if they are the "updated" version. should i be able to tell from the numbers on the injectors?
I was under the impression that the injectors we get today are the same as the ones we originally had. Wouldn't that be why GM prolonged the injector warranty to 7yrs or 200,000 miles?
No form all the research i did when i had my lb7 they updated the injectors in 2004 sometime to a "newer style". I know i have not heard of anyone that has got there injectors changed since about 07 going bad, it took awhile to get all the bad ones out of the system but from what i have been told is that if you get new lb7 injectors they last.
lb7=suck
lly=suck.... specially red ones
lbz=best motor ever
llm=suck
lml=probably will suck too
just my expert opinion
You better hope LJ doesn't see this. You may be safe since he doesn't seem to post much anymore.lb7=suck
lbz=best motor ever
llm=suck
And how do I get some of those fancy 12 second badges near your name??
