Long story but I will try to keep it short. It all started with indicator line not showing up on dash. No big deal I could pull-down to 3rd back to drive and was fine. I work on the road and didn't have time to deal with it so I let it go. About a month into this it reved and trans limped to 4th while running down the intersate camper in tow. This happened about 4 more times before I got home for Christmas. While at home I replaced nsbu and be cause it had a C0055 I replaced the speed sensor in the tranfercase. Could not get it to replicate the problem from before, with no camper. So today I head out to Texas for a job, camper in tow. It got worse and worse. Specs and codes follow.
2004 lb7
341000 miles on tcase
55k on built Trans not a bit of trouble towing on a 110hp tune from Rob.
I have never pulled this many codes from 1 vehicle but I am not a professional.
All Pulled with an action (My clone tech 2 died)
Transfer case
4- U1255 class 2 communication malfunctions
U1003
U1009
U1064 Loss of Bcm, dash integration module
U1024 lost communication withTcm
C0306 Motor a/b circuit malfunction
C0327 Encoder circuit
C0359 4lo discrete output circuit malfunction
C0379 front axle circuit malfunction
C0550 ecu malfunction
B0790 transfer case neutral indicator circuit
B2725 mode switch circuit malfunction
U 1301 class 2 data link high
And to limp it a P735
I am pretty sure new tcase is needed but I thought I would check with the pros.
2004 lb7
Transfer case
U1003
U1009
