Hang on. This ain't CompD, we are supposed to talk tech in fun threads, not talk smack in tech threads!
ok.... so a bully dog shift kit is the same as a sc v right?
Depends, do you have a dpf delete? or stacks? and how are your injectors?:rofl:
By the way, the Cummins not only crack.
So DockBoy are you going to put in an application for the Diesel Power Challenge,
I have too many teeth to qualify for sled pullingoke:
Johnboy,
It helps to know your facts before spouting off at the mouth
I was not spouting of Greg. I was correct you spent all your effort on adding power but did nothing to the bottomend and you paid for it. I knew it was not long for life when I looked at your pics and there was no paint.
The unpainted/rusty block that you speak of and that the piston seized in the bore in causing the rod to break was a STOCK UNTOUCHED 60K MI SHORT BLOCK:dontknow:
It wasn't "rebuilt" or even gone through. The engine was torn down to the short block merely to visually check things out. No mains removed, no pistons removed.
The new one is fully built and clearanced and by the way, painted:rofl:
I said piston numbnuts..........and that is EXACTLY what happened.
And this is for you Johnboy:rofl:
Looks good Greg. At least you had enough class not to paint it Ford Blue.:rofl: What Pistons are those 03s or CR Marines?
I know, I've heard you state that before, but it's part of the competition. Last years winner only moved the sled a few inches the first time after it had rained. Chris was very cool about it and would have let it stand but they redid the track (if you can call it that) and ran from the other end. I'm sure you could move it a ways. You should enter, nice to see you out west where the big power boys play.oke:
Plus it's always cool to see the Dodges struggle with high DA.
