How many build for 750 HP ?
mainer
Nov 11, 2008
326
did you do main studs on this build? curious whether that is being recommended or not seeing as though guys have put down so much power with stock bolts and had minimal walking issues
AdaMax
Nov 26, 2010
412
Caldwell , Oh
My goal this year is 700hp . My build is a little different because of the sled pulling rules in my area . The only thing is I am going to try to keep a stock bottom end alive by running cooler air charge .
3,733
305
That sounds like a sweet build. I wouldn't mind doing something like that for myself. Definitely keep us posted on the longevity of the build, I am very curious.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
About how much does the machine work run? Assuming you have all the hard parts and just need the keyways cut, assembled, balanced, etc..
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I did go with main studs on this build and do on most unless requested other wise , I have ran more HP than most with no main studs with no issue so i wont say there a nec item , but in the grand scheme of things its not that expensive to add them , they change the cost of a build by maybe 400 bucks minus the cost of new stock bolts and its even less of a difference .
Trent, whose stroker pump? Thanks.
II double Dragon pump
It will vary greatly from shop to shop but figure 2-4 K depending on if the heads need a valve job , the condition of the engine, and the level its re-assembled to .
aadd1998
Aug 29, 2016
Seeing how it's been a few years how has the truck held up? Wanting to do a similar build myself and hoping for reliability
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Trent disappeared from the diesel scene a few years ago.
My build is still running strong at 700rwhp. I never added any more fuel beyond the stock cp3 and my build had 46k miles, all on the big tune.
