I ask because that is the one thing that I didn't order from Guy. It totally slipped my mind when buying all the rest of my Hi-Po parts. Output is to be 1000+RWHP. Thanks!
Nick
Nick
I have billet caps, filled block, and a girdle, overkill? Probably but I wanted the bottom end as stout as possible
I don't think they're necessary, but I also don't think a lot of the stuff going into motor builds are necessary or have proven to make them stronger.
Interesting. I wondered about that too. What I don't understand is the LB7 guys, which includes me, still have problems with injectors lifting even with billet holddowns. I have those installed too but have yet to start the motor.
Nick
I have never lifted a cup.....yet with 90+ psi of boost
I do run billet hold downs
My last motor showed small sighns of crank walk after 3-4 seasons of 700+
i half filled this block and ran billet caps this time around with a girdle
time will tell i geuss
Nick
So are the guys that are lifting cups not have billet hold downs installed? I would think that on a built motor it would be a necessity.
Nick
Nick
Id rather go with the threaded/welded cups rather than the hold downs
