Question: how do I turn off the defueling in efi live
15,681
Good answer Mike. My only question is how can PPE remove defuel from their big tunes when it's the big power where you can have problems with no defuel? I don't know how they do it, but supposedly the excellerator can remove defuel from the ECM.
I build all my Alli's with extra protection against this.
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
WOW, I added some de-fuel to my race tune for towing, and on the way to work this morning i got beat by an celica GT cause it took forever to shift and i lost boost completly bewteen shifts. and 3rd to 4th gear was so hesitant it didn't shift under WOT, it kept on kicking in 3rd.:mad::mad:
And the previous time i seen the celica it wasnt even a contest with my quad tuner set on 215hp.
If it wasnt for the defuel id beat him even worse than i did before
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Defuel is there to prevent a tie up on a shift under high power and high rpm conditions. The ugly truth is the Alli is not capable of shifting fast because of its design. You can take the defuel out without a problem to the Alli if you cut the power down. You must give the Alli enough time to make the clutch to clutch transition into the next gear or you will tie it up. A tie up is being in 2 gears at once for a split second or longer. Picture 500 hp and 900 lb tq in a 7K truck under WOT being in 2 gears at once for an instant. Guess what's going to give? I will award a cookie for the correct answer. :baby::D
I'll take planetaries for 1200 Alex...:D
edit: damn too slow, lol
Huntinducks82
Apr 21, 2008
422
42
Centerville MD
Okay so i just learned alot obout alot. 1 ? How come two different tunes will shift so differenty without ever changing the TCM. I have one tune that shifts firm threw every gear. Then the other will have you eaten your steering wheel every time it shifts and they are both about the same hp.
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
post both tunes up for a look see ;)
