How are you guys heating your shops/garages?
CaptPhil
1,012
Delaware
I have a lopi Yankee bay. It is a bigger unit than what you would need for a garage. I will see if I can dig up a picture.
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
In my shop it has radiant heat, heats up very quickly, maybe 10 minutes and you can take your jacket off. Best way to describe it is it can be 40 degrees outside but if the sun is out and your in direct sunlight it feels a lot warmer simply because the of the sun rays.
My heaters work the same way, it doesn't heat the air specifically, but heats the objects in the room which heat the air, hence the name "radiant heat". After 10 minutes they are plenty warm to work.
In my garage (separate from shop) I have an air heater/fan and it feels totally different. With the air heater if I open the garage I feel like all the warm air is gone, with the radiant it doesn't feel as cold because your still being heated. I notice my hands get cold in the air heater rather than the radiant heat.
Here's the shop setup. Probably a bit overkill for a smaller shop but I have seen radiant heaters that curve around the shop so you only need to run one.
Thermostat
Heaters ImageUploadedByTapatalk1379472820.505396.jpgImageUploadedByTapatalk1379472857.255382.jpgImageUploadedByTapatalk1379472888.790194.jpg
9,905
151
If you have the right wood stove and know how to properly load it and set it it will burn all night or all day long. When I leave for work i load it and there is still embers in it when I get home that I can add more wood to relight it without effort.
But yes it is ALOT of work
Not really. Depending on where you live there are lots of places you can get dry already split. Just gotta stack it.
Electric log splitters take alot of the work out of it too.
But I say this as someone who doesn't mind doing it himself. A little exercise never hurt me none!!
9,905
151
Double barrel stove with a little 8" fan behind it, plenty of hardwood and the 30x40x12 shop has 3 ceiling fans.Toasty as you want it to be. I bank the fire in REALLY cold weather to keep it above freezing. As long as the floor never gets real cold you're good.
My buddy is wood heat in his 22'x22' garage and with his fan in behind the stove to move the air it's super dry heat and it's awesome. No better heat Imo.
Porno Joe
513
South of Pittsburgh
looking around the web I came across this one:
http://www.amazon.com/Pleasant-Hearth-Cabinet-Pellet-120-Pound/dp/B008R514Z0/ref=pd_sim_sbs_hg_1
seems reasonably priced, especially with the 120 lb hopper size.
has the pseudo-thermostat on the side, and thats fine with me.
Also still considering radiant heaters, though I dont know much about them. something like this:
http://www.teksupply.com/contractor...ssories-ts_tube_heaters;f6aae374_103205N.html
question about radiant heaters, could i vent them into the chimney already there for my natural gas furnace?
mreeves23
Big Hog Customs, LLC
Sep 15, 2011
91
Poseyville, IN
Biggest key to heating/cooling any facility is insulation. Keep the building well insulated (easiest done when built) is so important. I had insulation custom cut for my walls so there was no seems/joints in 2 different rolls between my posts. Also make sure all doors, garage doors, etc are well insulated doors and the same w/ windows. Drafts at all will certainly kill your heating. I have 24" of insulation in my ceiling too. I hardly ever run my LP furnace in the winter to keep the shop at 50deg. Like it may run every 2 days for just a bit to keep it that warm. If I'm in the shop I usually keep in 65-70. and once it warms up (approx 20min-30min tops depending how high you set temp). I do have 4 ceiling fans in my shop and highly recommend them. It was going to be $20K to install floor heat in my shop so I opted for the $4K heater and AC unit combo. Yes, my shop is Air Conditioned and without question, I would put AC in a shop before heat again. I can always use a torpedo heater/wood stove etc if needed to heat the shop but in the summer nothing like working in 75 degrees vs 95degrees. Floor heat would be awesome and is great once installed, just bit pricey upfront. But it all depends on the size of the building too. I run LP heat in my house too.
TexasRob
Dec 19, 2012
319
Canyon Lake Texas
We have the radiant heaters in a shop at work and they are awesome. Being a work building I couldn't tell you how much they cost but I know last winter when I was working I had to open a bay door to cool off. The shop is about 2500 sq ft and is completely uninsulated.
Cknight199
Aug 23, 2012
1,827
They can be cost friendly. It's not so cost friendly if they're on 24/7 and heat a large area.
ALLY Fox
Old Man Truck
Dec 14, 2010
434
Oregon 7S5
My shop is 40X42, 12' ceilings open beam 6" wood stud construction with one 10'X12' rollup and one tandem 38'X12' hangar door which is covered with 3" thick styro insulation panels. Ceiling has 10"-12" of insulation. It stays at 55* when OAT is 30* and If I need to warm it up for painting, etc I have an 80,000 BTU gas heater that will bring it to 65-70 in 15 minutes. It also stays at 60*-70* when it's 100* outside, as long as I keep the doors closed.
13,746
821
I picked up this heater for the shop today. It's a Dayton 4LX68 natural gas heater. 324,000 btu should heat the 40x50 shop pretty quick.
