The LML's are the best IMO. People get chubbies over LBZ's but I'll take the new chassis any day because we use ours. If you don't tow you will like the older trucks better and their cushy ride, if you do tow you will appreciate not being on the bump stops all the time. Sway control, hill start, exhaust brake, stability control, and massive brakes all make them nicer. If you want to put a plow on you will like the axle that can actually handle it.
Unless you are racing or something, you do not need any more power that what is stock. They can't keep the tires stuck to the pavement without the traction control as it is. 400hp is plenty for towing too. I like power as much as anyone, im not 80 years old either, but for a practical truck I think the power they have is perfect.
If you have troubles with the emissions equipment out of warranty, then delete it. In warranty, leave it. No reason to risk anything, you don't save much by deleting it.
We have over 100k now on our 2011 LML and its had the DEF tank replaced and an EGR valve, otherwise its been flawless. To me thats reliability, DEF components fail on everything. We also have a 13 with 25k on it and no issues.
Economy is 13-15 mixed pulling trailers and driving around. I don't care what other people say, we got 14-17 with our LB7s doing the same stuff. LML has much more power, it takes fuel to make power.
The CP4 issue is real but blown out of proportion, its nothing like LB7 injector failures. The CP4 fails on all platforms not just the Duramax. Read the TDI threads those guys are more paranoid than anyone.:baby:
They don't have the ability to push volume like the cp3??? I know they have the pressure to drive peizos so the psi is there but perhaps the volume is the issue? I belive they hve one less cylinder but I don't know the overall cc. but at reasonable tuning levels or stock I would say they do fine. That being said if there was an easy way (and I am sure there will be soon enough) to switch to a cp3 I would do it if I decided to up the power a large amount on the lml.
The CP4.2 uses two pistons, the CP3.3 uses a rotor like a wankel motor in a way with three chambers. CP4.2 is capable of higher pressures, but the one on the Duramax does not have the flow capabilities that the CP3.3 did. The CP4.2 is also timed whereas the Cp3.3 is not.
I've seen cp3's give up the ghost as well. So I'm not to worried about it...
When CP3's fail its no big deal, when CP4's fail they tend to contaminate the entire fuel system meaning you have to replace the injectors as well. CP3's can do this as well, but it seems like every CP4 is guaranteed to do this.
That won't happen so I guess we will hope for the best.
Exhaust wise… are these different than say the LBZ seeing how they have different frames? Looking for a cheap system with muffler or delete pipe/race pipe. He's an old man so he doesn't want it straight piped. The DPF acts as a muffler right? So eliminating that and the cat on the factory exhaust would be straight piping it? I haven't had a chance to really look at it yet.
Exhaust is different.
