How about an $800 Hydra-boost hose......
ripmf666
15,123
14
47
Wentzville Mo
H0813 - Pipe, Brake - Master Cyl To ABS Modulator Valve - Rear - Replace : Sonsabitches never replaced this like I told them too, they just put in a compression fitting to join the pipe where the hole was.
E5131 - Spring Assembly, Rear Leaf - Left - Replace : They never replaced this either, just adjusted it as the u-bolts were loose and the overload was halfway out of the pack.
J0920 - Oil Level Indicator Replacement : I wonder what oil indicator this would be? I don't recall the water pump ever being changed either..........:confused:
Good to know I got powertrain and engine warranty till my truck is paid off though! Thanks Henry!
Your Hose should of been covered under this.
9,905
151
I didn't think accessories like alternators, hoses, pumps, batteries were covered by powertrain or engine warranty? Just your regular new vehicle warranty covered that......
ripmf666
15,123
14
47
Wentzville Mo
Its hooked to the motor and works the brakes lol so should be covered.
This is the warranty for my truck the early 06 sucked guys that bought later lasted longer.
<TABLE width="100%"><TBODY><TR><TD class="h02 left" colSpan=3>Applicable Warranties</TD><TD class=right colSpan=4>Valid warranties are highlighted</TD></TR><TR class=gridHeader><TH class=center>Valid</TH><TH class=center>Description</TH><TH class=center>Warranty Add Date</TH><TH class=center>Start Date</TH><TH class=center>Effective Odometer</TH><TH class=center>End Date</TH><TH class=center>End Odometer</TH></TR><TR><TD class="center black"></TD><TD class="center black">Corrosion Limited Warranty</TD><TD class="center black">02/23/2010</TD><TD class="center black">06/13/2006</TD><TD class="center black">29 MI</TD><TD class="center black">06/13/2012</TD><TD class="center black">100,029 MI</TD></TR><TR><TD class="center black"></TD><TD class="center black">Diesel Engine Ltd Wty with Deductible</TD><TD class="center black">02/23/2010</TD><TD class="center black">06/13/2006</TD><TD class="center black">29 MI</TD><TD class="center black">06/13/2011</TD><TD class="center black">100,029 MI</TD></TR><TR><TD class="center black"></TD><TD class="center black">Bumper to Bumper Limited Warranty</TD><TD class="center black">02/23/2010</TD><TD class="center black">06/13/2006</TD><TD class="center black">29 MI</TD><TD class="center black">06/13/2009</TD><TD class="center black">36,029 MI</TD></TR><TR><TD class="center black"></TD><TD class="center black">Emission Limited Warranty</TD><TD class="center black">02/23/2010</TD><TD class="center black">06/13/2006</TD><TD class="center black">29 MI</TD><TD class="center black">06/13/2011</TD><TD class="center black">50,029 MI</TD></TR></TBODY></TABLE>
9,905
151
Ok well I will phone my dealer and ask them about it. If they say it should have been covered I will call the dealer that did the work and bitch. If they don't help me out, I'll call GM.
Thanks Henry.
9,905
151
Talked to my GM service manager at Stettler GM and he checked into this for me. He said the hoses and more surprisingly even the PS pump are not covered by Powertrain or Diesel Engine Warranty. Also I found out the trans cooler hoses I had replaced in Feb/08 were not the updated ones and are no longer under warranty so looks like I'm replacing all of those with hyd hose!
