Hook up Ipod to factory stereo?
HDdave
171
Wilmington, NC
I have a way to make an AUX input in our trucks that allows you to play your ipod for a total cost of like $8. I have already done it to my truck and all my friends or else I would make a step by step DIY with pictures. It is a little too hard to explain without that, but very simple once you see the process. If anyone is in the Pittsburgh area and has a truck with bose and the factory XM option, PM me and I could do this mod for you and get some pics for the forum.
As far as I know this only works on trucks with the factory XM option. XM does not have to be activated, just available.
Jetty LBZ
work in progress
Jan 24, 2011
404
33
middle TN
that sounds great. id let you install it on my truck but im nowhere close:(
tadams72
Mar 27, 2010
Anyone have any pics? I have some ideas of where I would mount it when I get one, but would like to see what others have done. Thanks. :D
Get the one from Crutchfield. It works great allows you to control everything with your steering whel controls/dash controls. Open the glove box and then push the lever at the back that lets it drop down all the way. Connect and mount using double side sticky tape to a flat surface there. Run the cable through the dash and into/underneath the enter console. Pull out the cup holder and pull the cable from under the dash and connect the iPod. Put the cup holder back in place and leave the iPod out of sight and prying eyes of thieves. Works great. :thumb:
SSTuner
Feb 28, 2008
Northern Virginia
Is this similiar to the mod you did?
http://chevyavalanchefanclub.com/cafcna/index.php?PHPSESSID=hdgblhgppmek6kv35g29vgddv2&topic=93646.0
Ray Lopez
2006 Silverado "Grey Ghost" 2500HD LBZ LT/CC/SB
6" Rough Country Lift Kit, 315/70/17 BFG AT, Raceline Renegade 8, RCX 2" Wheel Spacers and RCX Tie Rod Sleeves
EFI Live with EGR Blocker
Banks Ram-Air/Super Scoop
TranGo Jr. (awaiting install)
PPE Trans Pan (awaiting intall)
Mag-Hytec Differential Cover
5" Magnaflow Cat-Back with 4" MBRP Front Pipe
Edge Insight w/pod
Intake Heater Delete
RandoTx
May 6, 2011
93
ispec USA or somethin like that. hooks to xm and works/charges and plays pandora like a charm
fajitatone
Almost Stock
Jul 6, 2007
736
15
WA
www.fajita.net
USA Spec GM-15
you can use the steering wheel controls and it shows the names in the radio. also has an aux input, I use that to put my laptop audio so I can watch DVD's
