Info: High output alternators
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Looking to buy a higher output alternator for my pull truck. I added a 12V hydraulic pump for my steering this year and when I turn it on my volts drop from 13-13.5 to 11-11.5 quickly at idle. Anyone have suggestions on a decent one for a reasonable price. I like the Mean Green one, but it's $370!
Thanks Zak
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
I think I can get a Delco 205 amp one local, needs slightly longer belt in stock application.... Not sure on your belt setup currently...
N2BRK
2,054
371
just check the output of any new larger aftermarket alternator at idle speed. Some of them have awesome output but only above idle speed. Or carry a specially weighted brick to keep you at PTO idle :roflmao:
5,813
what do the volts do when you rev it?
you need to look at amp output at idle. i dont believe there is much difference in the 145 from the 105 at idle IIRC.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
The volts will go up a little if you hold it at about 1500rpms. I think I'm going to go with the Acdelco 145 alt and some new Odyesse batteries.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
I use Rare Electrical 200 amp alternators and haven't had an issue yet. I've installed about a dozen of them now, they are very reasonable through Amazon.com.
5,813
a good set of deep cycle batteries may be best. your drawing off the battery when volts drop under 12.6 volts
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Yeah, that's my fear that it will drain the batteries down too much and if I have to shut truck down for some reason it will not have enough power to restart it.
5,813
can you put an amp meter on the pump and see what its drawing? what gauge wire are you running to the pump?
i would be more worried about the truck acting up on you pulling and causing things to shut down as you pull from low voltage than a no start at the end of a pull lol.
