Just wondering what truck you own?
The spec from GM for a lb7 is
- min warm at idle is 14 psi ( seems low? )
- 1800 rpm = 42psi
- oil relief valve opens at 64psi
I thought its 74psi?
- 1800 rpm = 42psi
Did some looking around in the fsm about symtoms of having high oil pressure and could not find anything saying it was bad or it would have a cause. Didn't looks for the specs about the pressure relieve valve but when I get home from class ill check my books agains for the specs about the oil pressure on the 01, everything is different on the original lb7
I drove it around and idles for 30 minutes waiting for my carpool this morning and my oil pressure went down to 40 psi.
Danny besides blowing my frost plugs from the oil gallery ( not common ) and you blowing the seal on the sensor ( not common)
I dont see the harm in running high oil pressure.
I would love to see the specs on the 01
check the oil squirter pressure also if you can
