I thought it was "everything is bigger in Texas" ?Everything is better in Texas from what I hear!:thumb:
I guess they are??
You should start selling them, because you will make a ton of money!
Congratulations, you figured out the solution to the LB7 injector problem! Even the smart engineers at Bosch and GM couldnt figure it out!!! And they've been trying to figure it out/find a solution for the past 12 years!! Hats off to you!!!!! :beerchug:
I vote we make this post about better filters being the fix to LB7 injector failure a sticky.
Ben
Well, what is the most common failure? Mr. D.
Actually I do and they are all still running. On those injectors. If it isn't the cure it sure slows it way down. Better filtration is a must to keep one alive. Fuel lube helps as well. If you remove air bubbles/foam from the fuel that helps with the lubrication.
The cylinder head temp I am sure is higher than the oil temp.
No, the low sulfur doesn't help, but the number #1 thing that rebuilders see is................contamination.
And better filtration doesn't help? Huh
Removing air from fuel supply doesn't help? Huh
Guess the law of averages and physics are diff where y'all live
Maybe we should just run them without filters.
I have a fass and 2 micron cat filters on mine and its even an lly. I still have an occasionally loud injector and smoke. Guess I need to see somebody about a refund! :rofl:
You don't realize how far out of your league you are. You got lucky on 2 or 3 trucks . There were thousands that failed with YOUR kit.
Do you really think you discovered something? We are on the cutting edge here on this forum and you come up with " yawl need a better fuel pump and filter " GTFO.
We run wix in the stock location
The stock Wix Duramax fuel filters are junk in my opinion. Parker/Racor or ACDelco is all I will run in the stock location.
Don't try and run one of those plastic PS filters on a LML. I had some left over when I sold my LB7 and started using them up on my LML. Under hard throttle the engine would cut out at about 80 mph. I finally switched back to a GM filter and it stopped.
I'm just giving you a hard time. I don't drive the thing much and I know which one it is. It doesn't do it enough to make me want to replace it at this point. I have to agree with others, lift pumps and filters are not a fix for lb7 issues. But they certainly don't hurt and if you've been lucky enough to fix a few that way that is excellent. I have not been that lucky both personally and at work.How often do you have this issue?
