In my experience....This does fix it. You still have to change the filters for it to work but don't get any complaints from my customers that have performed this modification.
We have had great luck with the add on filters and lift pumps. Had a few pump failures out of the early air dog deals, but all were resolved and everyone was happy. That is the kit we use most if any one is wondering.
Have a few lb7s out there that are worked; not rode that have not had a hiccup ever since we replaced the factory fuel filters with the after market setups. One is at 215k on the injectors and fuel system. Changed it over bout 3 years ago had 190k on it then, and was on its 3rd set of injectors. Have a few others that have 100k or more on them and customers are happy. Most just change filters at 15k and separators at 30k. A few monitor and change by fuel pressure leaving the pump. When it drops to a certain # they change. All seem to be around 15k + or - a few thousand.
Sounds like you guys that are having problems need to swap your filters out more often.
Pretty sure the factory filter is a 7 micron. Found this in some program we use here at the shop.
<!-- DW6 --> <table width="661"> <tbody> <tr> <td width="481">
</td> <td class="print" align="right" width="168">
print this page</td></tr></tbody></table>
<table class="parentTable" width="80%"> <tbody> <tr> <td valign="top"> <table class="relatedLinks" cellspacing="0" width="230"> <tbody> <tr> <td class="relatedLinksC" width="20">
</td> <td class="relatedLinksH" valign="top">
Related Documents
</td></tr> <tr> <td width="20">
</td> <td width="195">
Warranty Info </td></tr></tbody></table> <table class="contentText" cellspacing="0" border="0" width="230"> <tbody> <tr> <td class="contentH" colspan="2" width="220">
Product Specs</td></tr> <tr> <td class="contenttbl" width="130">Part Number</td> <td> 33960</td></tr> <tr> <td class="contenttbl">Micron</td> <td> 7.00</td></tr> <tr> <td class="contenttbl">Height</td> <td> 6.300</td></tr> <tr> <td class="contenttbl">Outer Diameter Top</td> <td> 3.958</td></tr> <tr> <td class="contenttbl">Outer Diameter Bottom</td> <td> 3.472</td></tr> <tr> <td class="contenttbl">Inner Diameter Top</td> <td> Closed</td></tr> <tr> <td class="contenttbl">Duty Type</td> <td> HD</td></tr> <tr> <td class="contenttbl">Class</td> <td> HA</td></tr> <tr> <td class="contenttbl">ThreadSize</td> <td> 3 3/8-8</td></tr> <tr> <td class="contenttbl">MediaType</td> <td> Paper</td></tr></tbody></table> <table class="contentText" cellpadding="2" cellspacing="0" border="0" width="230"> <tbody> <tr> <td class="contentH" colspan="2" valign="top">
OE Cross Reference</td></tr> <tr> <td class="contentH" valign="top">OE Manufacturer</td> <td class="contentH" valign="top">OE Number</td></tr> <tr> <td class="contenttbl">General Motors</td> <td>89016324</td></tr> <tr> <td class="contenttbl">
</td> <td>97256734</td></tr> <tr> <td class="contenttbl">
</td> <td>97363539</td></tr> <tr> <td class="contenttbl">
</td> <td>97385488</td></tr> <tr> <td class="contenttbl">
</td> <td>98017645</td></tr> <tr> <td class="contenttbl">Isuzu</td> <td>8972567340</td></tr> <tr> <td class="contenttbl">
</td> <td>8973635390</td></tr> <tr> <td class="contenttbl">
</td> <td>8973854880</td></tr></tbody></table></td> <td valign="top"> <table class="feature" cellpadding="1" border="0" width="425"> <tbody> <tr> <td colspan="2" valign="top">
Fuel Filter
</td></tr> <tr> <td width="103">
Part Number: </td> <td width="312"> 33960 </td></tr> <tr> <td>
Manufacturer:</td> <td>
WIX</td></tr> <tr> <td>
</td> <td> Gastonia, NC</td></tr> <tr> <td>
</td> <td> 704-864-6711 (II)</td></tr></tbody></table> <table class="imageTbl" cellspacing="0" border="0" width="425"> <tbody> <tr> <td align="center" valign="top" width="419">
</td></tr></tbody></table></td></tr></tbody></table>
Activant Cover-to-Cover™
About Us |
Support | Copyright © 2014 Epicor Software Corporation.
Just my .02 and experience
