Okay, here's the deal I talked to TRS today:
1. Aftermarket "halo projector headlights" are POS. Halogen projector = nothing more than cheap chrome plated reflector bowl and beam cutoff plate. Mine are ruined from 55w HID bulbs (duh).
2. Buy OEM clear headlights (2002 model). Ebay? Good source would be nice
3. Retrofit OEM headlights w/ TRS projectors.
4. Since I have 55/50w h1 bulbs, if I want to use DS2 bulbs (TRS recommended), I will need AMP>DS2 ballast adapter & (2) DS2 bulbs
5. Decide which projector works best for OEM housing. Headlights are small. TRS recommended Bi-xenon: Morimoto Mini D2S 2.0.
6. Select shrouds.
Ben,
I want quad bi-xenon projectors in low beam & high beam location. Using splitters from TRS, how would a wiring schematic look to properly power both low beam & high beam? Is there a way to have both projectors (low & high) running low beam together and high beam when desired? When triggered, I want both low & high projector's solenoid to flip the cutoff plate up when high beams are selected. Is this possible?
Also might try to fab up mini projectors for fog lights since I have 35w HID's for those too. I definitely have my work cut out for me. Should be a good project every afternoon after work.
Here's a fellow TRS customer with similar lights (2002 model). Looks great!
