Hid brands
motoking_1990
1,957
5
Terre Haute, IN
I was wanting.g to if anyone knew of a company that makes good hids cause I have been having problems with my right one and now my left one is starting to flicker they were on it when I got it and one of them is a brand called aline. Any know if any good brands cause im in the market lol
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
4+ years on my chinese POS VVME's. :thumb:
Dont believe the "made in USA with american parts" BS. Their all made overseas.
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
I bought a set off of a member here last year. Don't remember who though. I'll do some digging. I haven't installed them yet but the quality of everything looks amazing.
Nick
08txlmm
75
Lubbock
+1 on ddmtuning.com. I've only had mine on a couple weeks now but I'm happy with them. A friend of mine has had some from them for several month with no problems. You can't beat the price and they seem to last from reading on the forums.
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
I'm interested in this as well. I know absolutely nothing about HIDs, though I'd like to have a set in my truck. My brother recommended ddmtuning, but I don't know the specs of what all I need. I want bright white with no tint, so I figure I need 5K.
I have the all-on mod so I want to install HIDs in the highs, lows, and fogs.
My major concern would be splicing into the factory harness...if I have to, HIDs are not worth that to me.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I have Retro Solutions on the truck. Had them for 5 years, one bulb burnt out but Todd replaced it under the lifetime warranty, no questions asked. Great service. I have the 5,000k 55watt in my low beams and HIR (not HID) high beams.
I have the cheap DDM HID's in the fog lights on the S4. Only in the foglights because the headlights are HID from the factory. It was like 30 bucks for 3000k (yellow-ish). They work perfectly so far, and dont cause any "foglight bulb-out" warnings either, which is nice. (newer audi's monitor/warn you when any bulb is burnt out on the car)
No complaints with either the "nicer" expensive Retro Solutions HID's, or the cheap-ass DDM HID's...
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I think the VVME's were 150.00 bucks to do High/Low/Fogs. No flicker issues what so ever... I couldn't believe the difference in lighting with the all on mod done.
Chevmeister
Big Dooley
Dec 3, 2010
281
Garnet Valley, Pa
I've done 03 up trucks for under 100 high, low, and fog. IMHO 5000K gives you the brightest white light. From what I've read 4300K is supposed to be true white.
Listed as highs, lows, and fogs respectively
For 01-02 you need 9005, 9006, and 880 bulb types.
For 03-07 you need 9005, 9006, and 9145 bulb types.
For 08-11 you need 9005, H11, and 5202 type bulbs.
On the 08- up truck you have to disable DRL, I believe it's just pulling a fuse or two.
Once you have HIDs you will never want a vehicle without them.
Whitetail Addict
May 8, 2008
2,350
Thanks for the info guys!
Do I have to splice into the factory harness or is it all plug and play? Where have you found to mount the ballast? Also what wattage should I get 35 or 55...I've heard horror stories of HIDs causing electrical fires? Lastly, do I need to buy projector housings?
Ian J
123
Nov 5, 2010
41
Merredin Western Australia
What bulb type and color should I get? From DDM. I have never bought these mind you!
__________________
For globe colour with no funny effect 4.3-5K is what works best.
I have specialised in HID for nearly ten years and I alway see people go for 6k and above but you will loose 30% of your total luman[actual light volume] if you go from 4.3K to 6K. 5K is about 10% reduction in out put but can be a good option as the slight increase in brightness can be a advantage without the weird effects you get from higher coulour globes.
I could send you some nice stuff but the freight would be a fair bit:thumb:
motoking_1990
1,957
5
Terre Haute, IN
What do you have have and how much? Im in the market like I said
