help
ecc_33
Junior Member
Aug 10, 2006
1,925
39
Amanda, Ohio
How big are your injectors, whats your max pulse width, What are you commanding for rail pressure? Still BIG cp3?
ecc_33
Junior Member
Aug 10, 2006
1,925
39
Amanda, Ohio
Todd, He means pulse width of the injector not the rail pressure. How big of a pw are you running. 2200,2400,3200 etc.
ecc_33
Junior Member
Aug 10, 2006
1,925
39
Amanda, Ohio
Seems like your running good rail pressure so I would add more pw to the injector if its not real high already. We have ran as much as 3200pw with 80% injectors on a lb7. The truck seemed to like big pulse width with big sticks.
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
pw 2650 running 2650
Like Eric said I just wanted to make sure the pw you commanded is what you get
My stock pumps with 2600pw will hold that rail its not until I get to 2900 that it starts to drop
If you don't want that much pw and timing you will need bigger sticks
ecc_33
Junior Member
Aug 10, 2006
1,925
39
Amanda, Ohio
bump the pluse width up until you start to loose rail pressure then back it down until it substains desired rail pressure just like simon said. I would also advance timing with the added pulse width.
ecc_33
Junior Member
Aug 10, 2006
1,925
39
Amanda, Ohio
Thats a good rule of thumb simon. Alot of people are scared of timing. I always ran a max of 39* with my stock injectors and 3200pw. Nitrous and water/meth was the same exact tune. My engine looked GREAT outside the bent rods lol.
TNRGreene
Kicked to the Curb
Sep 2, 2006
2,911
Bradenton, Florida
thanks working on it. had a great weekend pulling even with the issues. I knew with all the changes there would be some testing. nothing broke & we learned a bunch :thumb:
