need help with a simular issue. can drive all day but then puking coolant when parked but never over heats or has temp fluctuation. also did a head gasket co2 check and showed to be good. takes a long time to come up to temp. tried bypassing egr cooler with no change. next was thinking of trying to replace t/ stats. also read one post about oil cooler plugged causing coolant to puke. but when clicking on the link it took you to a psd 6.0 sight. so not sure if this is an issue with a dmax or not. also did a head gasket co2 check and showed to be good.
