Looks like GP #6 went bad is there anything I need to know about replacing it? Other then don't break off the tip in the engine. #6 is the 3rd one on the driver side right? The TQ specs for the LLYs are 13lb ft is the LBZ the same or close enough? Anti seize?
I read on a TBS posted on DP if
"Ignition OFF, and the affected glow plug disconnected, measure the resistance between the affected glow plug terminal and ground with a DMM for less than 1 ohm. If the resistance is greater than 1 ohm, replace all of the glow plugs."
correct? If thats the case I'll let GM do all 8 for the $100 deductible.
Thanks
Thanks
