Help with engine power reduced
2,208
I'm going to guess that most if not all the problems are a result of the delete and tune
2,208
has the throttle blade been disconnected or are the electrical plugs still plugged into it? its a known issue that if the truck is deleted and the throttle blade is still on the truck, the blade needs to be disconnected.
first time hearing about this. never had any issues with mine when it was deleted and the throttle blade remains intact and plugged in
Reactions: 08lmm72mm
5,911
I think it depends on the tuner from what I remember but it can cause his issues. There was a couple guys who had that issue on here before
2,208
well then I guess my tunes must be better then I give them credit 😁
