help with airdog pump
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
I bought an airdog pump and for some reason I had in my head that it was a raptor. too late now, so I need to make this work.
All I am looking to do is have an inlet and outlet. The airdog pump I have is just the pump assembly and no manifold or filters. See the pics below. need to know how to cut an aluminum manifold and make this work. I understand the small hole for a case drain (pump blow-by and lubrication) but I don't quite understand the check ball that goes in the oval slot (inlet or outlet?)
A pic of the top of the manifold that this bolts down to would really help me figure out what I need. Can someone take a pic for me or maybe just explain what I need to get this to work?
Thanks!
Russ
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Gonna revive this one.
Are you just looking to purchase a base and parts to get your's working?
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Well with what you have you're never gonna get it to work unless you get an airdog base. The motor is the same as a raptor but everything else is different.
That ball is to allow the unit to get suction or pull fuel once it's mounted to the base.
coker6303
Aug 6, 2009
2,484
40
Houston, TX
I figured it was some sort of check for holding a prime.
Pm me a price for the manifold with no filters, my bro could use it on his 2011 6.7 dodge
sent telepathically via rooted ThunderBOLT
