HELP!! No Power!
txhotrod
Jan 26, 2011
2001 Dmax has no power when you accelerate mild to hard off of a stop or during driving. It will barely get over 25mph. Had low fuel rail pressure and signs that the Cp3 was dying( almost 300,000 miles) Now it still has the same issues, does anybody have any ideas??
Thanks,
Joe
JMK777
16's, but i keep em clean
Mar 20, 2008
1,433
5
Moss Beach
Cp3 could be bad or could be in limp mode. How many codes? Did you clear the codes and it still dose it?
txhotrod
Jan 26, 2011
Sorry its 2001 2500hd work truck no mods, completely stock. almost 300,000 miles could it be the injectors???
Yes, I did clear the codes and it still is doing it. BTW they have not come back..yet
Thanks for your answers!
Jetty LBZ
work in progress
Jan 24, 2011
404
33
middle TN
just a guess but your fuel filter could be stopped up if you bought some fuel from an older station. i did one time and the next few days my truck wouldnt go and it gave me a low fuel rail pressure code so i changed the filter and that fixed it,
13,735
804
Thanks,
Joe
You said it had signs of a bad CP3 and now it is doing it again? Have you done anything to fix the truck? More info would be helpful. If it is low on power and throwing low rail pressure codes you either have a restriction on the supply side, a weak CP3, bad injectors, or a high pressure fuel leak.
txhotrod
Jan 26, 2011
OK we had a coolant leak, O ring did not seal properly :mad: But its back together now. Went for a road test, still have the same issues. The replacement of the CP3 took care of the no start issues. I can accelerate from a dead stop fine, but only up to 25 MPH then it loses all power. I guess it is going into "limp mode" ?? I hooked up the scanner and there are NO CODES!! WTH!! This is driving me nuts!!!:angry5::angry5: I hope one of you out there has an idea!!
Thanks!!
13,735
804
Do you have anything you can use to datalog? Where in TX are you?
txhotrod
Jan 26, 2011
Yes fuel filter was replaced. I have a Snap-On Solus Pro VS 9.4 I can't get it to read the injector balance though.
S Phinney
4,008
Quncy, Fl
Did you clean your tank and pickup when you changed the cp3? It is highly likely that it has a restriction from growth of black algae in the tank.
txhotrod
Jan 26, 2011
NO we did not drop the tank, but the tank was cleaned and serviced about year ago. Could this be transmission related??
13,735
804
Did you watch actual and desired rail pressure with your Snap-On scan tool?
txhotrod
Jan 26, 2011
Took it for a drive and it finally popped a code P0993, now I finally have something to go on.
vitaliy
Jun 9, 2016
HELP !!!! HELP!!!! 11 Duramax power loss
Hey guys, I had the weirdest thing with my chevy. Today my duramax instead of picking up and going it started to drive slowly and lost power, no check engine light came on, when I kept driving, i know this that the power was getting weaker and weaker, eventually I got to the point where i couldn't pull in to my drive way, the truck starts and runs like nothing happens but doesn't want to go when you try to move it. I have full egr delete, and the cat as been removed, what can it be? please help, This truck was pulling great until this happened
