New motor is in. It cranks over and only trys to fire a time or two after cranking over for a few seconds but it never starts. Rail pressure goes up to around 7000psi while cranking but injectors don't ever seem to fire.
Each time I get DTC code p0336 (Crankshaft Position Sensor A) - status MH
I also logged PID - "Cam Reference Pulses Missed" shows 37 - 40 counts after several seconds of cranking.
I swapped out both sensors with the ones that were in my original LBZ but is has not made any difference (code still shows up). I can see & feel the cam relucter plate behind the cam sensor. I never looked at the crankshaft relucter on the new build since I picked the engine up from the machine shop fully assembled with the front cover installed, cam, heads, and valvetrain installed. They are a reputable machine shop with several D-Max builds under their belt.
Suggestions on what to try next??
