Well you guys as well as I know the notorious injector problem... Well here's my caveat. I changed the lft bank first (btw what a pain). well I got codes for 1 7 4 and 2 and 1249. Well dunno what went wrong. So I changed the right also. same codes I have ohmed the wiring through the injectors from the FICM. All injectors ohm out. So essance I have checked the wiring power and ground side of all injectors through the splices also. Could I have accidently fried the FICM? Is that possible? What else should I approach? Don't want to go to the dealership.
