i just installed a lbz cp3 in my lb7 along with a brand new lbz reg. now my truck wont start!Truck ran fine before i took it apart just wasnt building enough rail pressure (example)desired was 23,000 actual 13,000 so i decided to change cp3,my injectors wer done about 12,000 miles ago,i double checked all the connectors i disconnected ,cracked the bleeder on the filt housing bled that!just cranks and cranks and cranks?I was told the cp3 i had bought only had about 30,000 on it? i know the reg is brandnew for sure and is humming when key on! Any suggestions?
