I was beating on my truck last night and I backed out of the throttle and the truck started to shake violently, at first I thought it was a tire but when I stopped and it was idling and still shaking bad, I knew it was worse.
I had orignally thought it was the harmonic balancer, I got up early and went out to check on it, the bolt was loose...............so I tightened it think that was the issue I started it and still had the vibration. I drove it to my buddies shop and had him look it over. I pulled the balancer and found that the pin in the crank that holds the balance was sheared off!!!!!!!!!! WTF!!!!!!!!
How can I get it out? I don't want to pull the motor and have the crank keyed. Has anyone had this issue? How did you fix it?
HELP
HELP
