Seen this posted on a different forum. Has any one else seen these and any one running them ??
Xtreme 2500 / 3500 Chevy Lifted Truck Axles
[RC001HD] $495.00
The RCV Performance total solution to all your lift induced axle problems. Inboard joint provides up to 40° of joint articulation to allow for maximum lift and wheel travel. The stock inboard joint often is the limiting factor only allowing 15-20° max before causing anything from vibration to complete axle failure. Joint spacers are often included which allow the axle to be bolted back up but do nothing to address the real problem with lifting truck axle geometry. From full droop to full compression RCV’s slip splined center shaft provides ~ 2.750” of length change. Axles come completely assembled with high angle boots and xtreme duty grease. 30 day 100% customer satisfaction guaranteed.
*$495.00 PER SIDE.
[RC001HD] $495.00
*$495.00 PER SIDE.
