Are heatshields, heat wrap, turbo blankets necessary.? When you install a downpipe, uppipe wrap, turbo blankets or reinstall heatshields what is the reason for them.? I reinstalled my turbocharger heat shield after I installed the downpipe, a blanket was not in the budget and figured the heatshield would do just fine....
1. To retain heat in the turbocharger system for maximum energy efficiency.?
2. To keep under hood temperatures down.?
3. To keep noise down.? (I have a sleeve on my hotpipe and downpipe (Thanks Levi) sure gets rid of the turbo whine in the cab.
4. To protect other underhood wiring etc. nearby from melting or being damaged.?
5. If heat shields are not needed why did GM install them in the first place.?
