Help: Header gaskets
2wd_Sled_Puller
Heavy Equiment mechanic
Feb 19, 2008
1,356
Florida
What is up with the header gaskets on sbc i have replaced to so far on gas hog. I am going to put regular manifolds on it tommorw and see what happens.
Jun 28, 2007
3,259
NE Pa
flanges prob aren't flat, cut the flanges so that the front and back are independent from the center 2, see if that helps, if not put them against a belt sander
2wd_Sled_Puller
Feb 19, 2008
1,356
Florida
Ok thanks paul. I will do that sometime right now work is crazy so i will put a regular set of manifolds on it for now and play with my headers in my free time.
552
are you use the one for the iron log manifold on a tubular header setup? they will blow out ever time if so.
i use felpro 1444 on both my 305 and 383... reuse them as well.
tbj
150
Mills Co., Texas
You really just have to check them often. My first truck I had to replace header and collector gaskets at least once a week because the bolts would loosen and cause them to blow out.
