Head Gasket Repair starts this weekend
LB7Diesel
Oh Boy!
Sep 3, 2006
1,355
Melbourne, F.L.
Did the Head bolts break inside the block, or are they sticking out a bit? Either way good luck getting those out.
Don't forget Michelle's B-Day on the 17th!!! Your part's pile is covering your calander!:rofl:
9,905
151
You will probably need a machine shop to mill out those bolts and re-thread the bolt holes. I'm sure Guy would be able to help you with getting that done!!
Good Luck with the build boys!!:D
dieselson
1,544
30
Huntington Beach, CA
They are sticking out a bit, and :rofl: thats my little sister, didnt notice that lol.
dieselson
1,544
30
Well, the news is not good. It looks like its gonna need a full build, with .20 over pistons, bore it a little bit because of the rust and pitting in the cylinders, get the welded bolts out, and I looked again and none of the pistons come above the deck, also the heads are for sure warped, so at this point, we have decided it would be cheaper to find a good, cheap used LB7 engine, so if anyone finds one for cheap, tell us about it, because we cant really afford a motor build right now :( :barf::cry::thumbsdown::broke:
ripmf666
15,123
14
47
Wentzville Mo
How bad are the heads warped, Gm has a big gap they give you more then I thought they would for warp on the block deck and heads.
dieselson
1,544
30
hey this is dmitri i am really good friends with wade he does not have anything that can really help this situation :( we really need some 20 over pistons or a good long block with some miles on it if anyone out there knows about either one for sale.
dieselson
1,544
30
not sure on how bad the heads are warped we didnt put a straight edge on them yet. We might send the heads to guy to have them looked at and maybe get a set of castings from him depending on the results
