If nothing on your engine had changed, and it came with A & B gaskets in the first place, then just swap the new B's in and be done. But if you've had the heads decked, then you've changed the p-v clearances and you should just use C's.
Ok thats what i was looking for. Was not sure if the change in the p-v clearance would be enough to effect the gasket selection so since you guys are aaying that it does effect the selection i will order new gaskets from henry and hope like hell the machine shop will give me money back for the ones he ordered.
Thanks for clearing this up for me.
