Help: Head Dowels
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Good luck I still have not gotten a number for these.I have a extra one I could measure.The ones that we use in are heads kinda look like the ones on the rear main,its not solid it can spring close some,They try giving you solid ones that are way to big.
That doesnt sound good for me....the said the dowls are solid now
Ill find out tommorow i guess
Illl post up the PN/ and see if they match with Guys
So the rear cover dowls are not the same ones we use on the heads:confused:
Trippin
SoCal Diesel
Aug 10, 2006
663
The rear cover dowels are the same diameter only shorter, I wouldn't use them for the heads or vice versa.
ripmf666
15,123
14
47
Wentzville Mo
I will go out and shift thru my dmax parts box lol.I have a few of everything in there and measure them and take a pic for you.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Hole in the heads = 0.582 x 0.254" tall
Hole in block = 0.582 x 0.146" tall ,
Total lenght = 0.400 + Gasket
Dowls I have are ( i think for ) rear cover ?
Rear cover dowl pin 0.555 compressed OD 0.569 uncompressed OD x 0.356 tall
BigNuggz
Oct 19, 2008
9
They ain't nothing special my machinist made them with a lathe last time I needed some it took him about 3 min. Measure and cut done.
13,746
821
Simon, I just looked at my parts, and my head alignment dowels appear to be the exact same as the flywheel housing dowels.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Looked at a lb7 locator pin for the heads and one for the rear cover
they are different.....They have a slanted angle and are longer and a little thinner for the heads.
Twice now GM has given me PN# that guy posted and They are not correct. But is the correct number but they dont fit. There is something about discontinued stuff:confused::confused: Also it is a different PN# for the rear cover dowls
Maybe LBZ are different?
If you have them Russ,Hold onto them:D
Im going to have some built from a machine shop.
Trippin
SoCal Diesel
Aug 10, 2006
663
The trouble is, the GM parts info is really unclear on these little buggers, so we took our best guess. :(
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
bad pics but you can see the difference and yet they have the same PN# from GM
I ended up just getting some machined
ripmf666
15,123
14
47
Wentzville Mo
sukcs we can not get the part #.I asked the dealer if we took pics if we could show GM the one they try passing off and the right one.
