2011 lml with 68,500mi starts hard only when temps drop to single digits. No codes glow plugs are working with meter and key on they start at 5.2 volts then it slowly drops to 3.8 volts and voltage goes away after three seconds . 10 degrees and warmer let glow plugs cycle for 3 seconds starts right up. I’ve had this truck sit in negative temps for more than 48 hours and fire right up with the remote start when it still had cp4. That will not happen now just cranks and stubbles for 10-15 seconds while cranking then stops and you have to get in it and try again I’ve cycled glow plugs no change. Truck has exergy sportsman cp3 with PPEI tow tune.
