Allison 5sp: Hanging Shifts & Codes
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
O/t -
Othrgrl, what is this causing (incorrect speed reading in the trans?) and how would you go about fixing it?.......I believe I had the same problem a couple months ago with my one tune (adjusted ecm for 265s), but it never threw a code.
Start with making the pulses per mile correct , you should be able to get the spec off of the tire manufacture web site .
I'm learning alot from this thread.....might need a little clarification on my original question though :D
I never even opened a tcm tune.....didn't want to mess with it and create a tie-up....so I'm unsure of the parameters.
i usually dont mess with anything but shift points . maybe start with 100% throttle and WOT . get that down and change as needed from there .
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
What more is done to it? I have the same compressor in a modded VVT turbo and some 90hp injectors (that I got for free) on a stock LBZ CP3 - my rail pressure would never hold like it should have and I was very limited on fuel. I never ran with the headers. Once again congrats. And what does YOUR truck run? Did you ever hit those 12s?
15,681
You guys must remember that these fighting kids that know it all just recently learned to whipe their ass after a dump.:D
