My trans is hanging in 4th gear at times. Most of the time it is when I can't get ehough speed built up initially to get to 5, like after pulling out of a stop sign. Then when I can it hangs in 4 sometimes up to 70-75mph. Usually 1/4 throttle it will shift fine, if I go more it usually won't shift. Sometimes I have to go to 3/4 throttle to get it to shift. Sorta like it has to go out of grade brake mode.
My tune has throttle response increased and I didn't know if this was related to the throttle position sensor, also wonder if I should change the torque table, I am using the stock torque table with a modded McRat tow tune. I am new to the tuning and trying to learn what to change exactly. Thanks for any help.
