Hairline crack = bad vibration
Cornell
LBZ for life
Sep 11, 2006
1,601
Minnesota
I got my truck back on Saturday. My friend who works there said the transfer case was about ready to fall off.... :rofl: Hes going to grab the broken unit from the shop on Monday, then I'll have some pictures of the "hairline crack".
Cornell
LBZ for life
Sep 11, 2006
1,601
Minnesota
I got to stop by the tranny shop and picked it up... heres some pictures.
The crack goes a full 270 degrees around
Shiresy
Sep 27, 2008
S.E. Saskatchewan
I just got a phone call from the tranny shop and this is what mine did again! This is the 2nd time this has happened. Its from worn out U-joints I think but I stopped driving it as soon as I noticed the U-joints getting bad and it was still too late. I guess that brace would be the way to go.
SmokeShow
6,818
Lawrenceburg, KY
I've had two crack on me. After the first one, I also had a SC trans brace installed and if you read carfeully, I said I've had it happen twice. I'm thinking that brace is a waste of money??? Not that I expected it to, but it doesn't help with bellhousing cracking either. :eek:
You can get a new tailhousing for about $600. Let me ask n see but I may know of one available from a 5-spd truck a friend of mine has...
C-ya
Shiresy
Sep 27, 2008
S.E. Saskatchewan
C-ya
Thanks SmokeShow, its for my work truck and I don't want to sink too much into it right now. Its an 01. It also needs a flywheel cause the starter is slipping on the ring gear about every 10th time you go to start it.
Cornell
LBZ for life
Sep 11, 2006
1,601
Minnesota
Oh man, this thread brings back bad memories, I'm going to go check my u-joints now. :rofl:
The tail housing was like 600 bucks alone. :(
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
Change the ujoints and don't buy the kind with grease fittings; that would be a big mistake.
Greasable ujoints are hollow and cannot take the stress. They will fail.
i have had greasable u joints in for almost 20k miles and a dozen sled pulls and the same amount of runs down the track......no issues yet.
I do have New GM ones ready though, just in case, but i wanted to try these out and have had them in since before IronHyde was ever used for anything other than DD.
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
904
31
Western MA
www.matpa.org
That's because you don't have the power to break it. :eek:
J/K Where's the nutkick smiley when you need it.
Tests have shown the solid to me much stronger than the greasable ones. Alot comes into play on how/when one will break, but I have solids in all mine and the superstock boys learned long ago to stay far away from the greasable ones. If they are still in Ironhyde I would at least check them before too long.
maxaholic
1,876
40
Central, Texas
Damn thats nice. Guess I'll be taking the greasable joints I put in 50k miles ago out. But mine are not factory replacement joints. They are supposed to be a beefier joint than factory size.
