LBZ: Hacks
BrandonLLY
116
Ok well since you did not enjoy my under the seat race tune switch (best one you will find), I have seen one other one. These guys took off the quick disconnect bolts on the radiator while camping. So basically what they did was turn this
Into this
Portable hot tub Baby!
036.6turbo
747
92
Are there any other REAL hacks like this one that everyone should know about?
Here is one I found out about last week. I've been driving this truck for (9) years and constantly adjusting both drivers and passenger side temps, darn near every time I touch the HVAC control. Turns out you can sync them by holding the "AUTO" button down for (4) seconds.
I sure I'm the only one who didn't know this.
juststrokeit383
Jun 3, 2015
22
35
Hell yea! I didn't know about this!
Thank you for contributing to MY forum!
juststrokeit383
Jun 3, 2015
22
35
Into this
Quit trolling or gtfo.. I'm for a good joke but damn
ty_LBZ
Camaro killa
Dec 6, 2014
297
Farmington, NM
Wow! I'd buy you a beer!
5,911
on 03-07, put your key in the driver door key cyl, lock the truck with it, then unlock twice, open door, tap the horn and start the truck with door open and dome light off.
windows will auto roll up every time you shut the truck off. if you tuned the truck, you may have to do it a couple times for the BCM to accept it. kinda like when adding a DSP5 to a 01-02 makes the radio shut off every time the key is pulled :D
BrandonLLY
116
^ That was the first one I learned. Although you forgot one step. I was told I had to pull the window fuse for this to work correctly. Maybe that's why It never worked for me.
juststrokeit383
Jun 3, 2015
22
35
Couldn't you just shut your dome light off before the entire sequence?
1,941
I had no idea about the all-windows up deal, let alone syncing the HVAC controls. :hehe:
Kamilmk
420
Seymour, CT
Removed all the trolling/non contributing posts, b/c it looks like this thread might actually go somewhere. Who knew?
Sent from my SAMSUNG-SM-G928A using Tapatalk
rennat_2006
Feb 18, 2010
Pasco, Wa
Not a legimate hack and i wouldnt recomend it but ive seen a few trucks hr meters get reset to zero when the oil dipstick is removed and accidentally hits the positive battery terminal and the ac line close by to it. My truck is one of them.
5,911
Im trolling Tom. look at my "edit" at the bottom of my original post. :D :hug:
9,905
151
Ha thought is was the only one that ever did this. Cost me a dipstick. Didn't reset my hr meter though.
JLB7
Oct 27, 2015
13
California
When you are driving down the road and your HVAC is OFF but that annoying cold outside air is still coming through the vents. Turn your air circulation ON.
:thumb:
