Grand Tracker continual build
5,911
Can you not raise the frame mount on the pan-hard? or are you trying to have it parallel at zero articulation?
I can but it would have to go up 3-4”. Yes, I want to keep it flat at ride height or a little negative as it will create the best characteristics for on road driving and keep axle swing at the minimalist amount. With it moving 15” up and down, I don’t want it to make the back end feel squirrelly.
Kinda decided on running a bushing on one end and heim on the other so its adjustable still but will hold the angle up above the diff
5,911
Triangulated 4-link it :D
That really crossed my mind yesterday lmao. The truss is too tall and makes the link ends at the axle separate too far between upper and lower (gives me a high anti squat). The joys of working around a body and stock frame.
wilrob
Back in the Motherland
Sep 14, 2016
366
Dallas, TX
Yeah the more I look at the truss the more I see how high those link ends would be... high anti squat is no bueno for a DD. Just weld some brackets on the front of the truss :rofl:
wilrob
Sep 14, 2016
366
Dallas, TX
aaaaand nevermind, you'd have to move all the lines on the passenger side frame like you don't want to anyways lol
5,911
Yesterday I picked up all the steel I need, 2x4 plate in 3/16 and 1/4”, 2” .250 dom, and 1.5” .250 dom. Then spent the rest of the afternoon trying to figure out a good routing and mount for the Pan hard bar. The single bend over the diff still wouldn’t work. Came up with a new idea that has it bend around he back side of the diff cover and will require me to put a bushing on one side to keep the bar from rocking.
So today I cut, chamfered, drilled holes for roset welds and welded the threaded bungs in the steel links. Slapped some anti seize in the threads and put the links on the rig
dc3f4ca3af9ef9d9959f7d7fe9bad080.heic
Then it was time to see if the little pro tools bender would bend the 1.5 .250 dom.... nope, broke the u-plate shank right off at the die (pulled out of the weld). They only do a single little pass on them so I turned the welder up, put the tab back where it goes and buzzed two heavy passes on the die. Put back together and she actually bent the tube well, just need a 6ft cheater bar lol.
6ff092a884a3999279bafa709bd5fa29.heic
Made a 2” wide bushing out of left over 2” .250 tubing, cutting some poly bushings down and cutting an inner sleeve down. Still need to add a zerk in there for grease. Plenty of clearance between diff cover and bar.
7bc2e8b5f7a9e7a2a623e218330b087c.heic
I can raise the bar up one more hole and still have clearance at full bump so I’ll do that to get the bar flatter. You can see the new axle mount on the left as well. Top will be open to get a nut down in there.
Lots of clearance all around at full bump
1d9432b2a1ee164de83f5430c7ec1ed6.heic
0c211e2af4eebbbb1d12eb68a6d03a11.heic
5,911
Yesterday I spent the morning trying to decide on shock mounting locations and pros/cons.
To mount the shock correctly so valving is most effective and get max travel. Shock has to go waaaaay into the interior, mean I loose cargo area and hear the shocks/springs more daily driving. If I mount the shock low enough to not go into the cab and placed behind the axle, shock will be sitting waaay too low to the ground. Or I mount the shock with the top laying back towards the rear which lets me suck the bottom of the shock up into a reasonable area. Problem there is shock valving isn’t nearly as effective as the shock goes into a “falling rate” as it compresses meaning the shock shaft speed decreases as suspension compresses even if the suspension compresses at a constant rate
I was running different scenarios in my suspension program to see where it would put the shocks on the rig and thought “**** it, we are running these bitches into the cab”. So I gutted everything
1a7ceae509082fe5cc6cffaf0beb7204.heic
At that point I still didn’t have that “warm fuzzy feeling” that I was going to like this in the end. Sealing the shocks from the outside and the noise being my concerns. So I figured, the dummy peej guys mount their rear coilovers in a falling rate, let’s just give it a shot first. Mounts won’t affect anything should I change to putting the shocks into the cab. If I don’t like it down the road, I’ll put them in the cab and go from there.
So started in the mounts after lunch. Put 1/4” plate on the frame to give it strength. The crossmember tube already there is .160 wall 1.75” stuff which is nice. Then bent up some 1/4” plate to tuck the shock as close to the body as possible and made some kickers off the back plate for strength. May drop the gas tank and plate the back side down to the frame too, not sure yet
539d590ebefd7656bb26c5785412f5db.heic
266e9bc9101c4265a6f195eeae859e92.heic
This will be about where the shock mounts on the axle. Yes it’s low, yes it will grab rocks like no ones business but I’m planning on seeing more dirt trails/excursions than rocks but I won’t be afraid to take it down terminator and drag these bitches. It’s only 1/2” lower than the backing plate (pic makes it look worse)
d5cd773b92f84d7edea97853788201a4.heic
5,911
Today I got the lower shock mounts made on the driver side and then built everything for the passenger side shock mounts (frame plate, upper shock mount and lower shock mount
fbcf29bacce85bf1e7961f4855f17ecb.heic
811b7aaa13f496b024fe9f2515e8d846.heic
36952f7a606801f7ed1ea3acfcb17d53.heic
And then started to cycle everything. Springs rub a bit on the axle at full droop so I’ll pull the axle mounts back a bit but the shocks are going into a bind at the upper shock mounts when I articulate it. I’ll probably cut the outer tab out and widen it some (space it away from the shock).
Almost full droop.
1e64cd6e254949e1bd8a8d5dd9dd39a6.heic
Came a hell of a long way in a week. Just a lot of little shit to do now.
Dozerboy
4,916
496
TX of course
The work that goes into doing something different... It will be pretty cool when you’re done.
5,911
Fixed the shock mounts and got everything cycling well. Moved the bottom mounts back 1/2”, widened the top mount 3/8” and moved the back hole on the upper shock mount down and forward 3/8” to put the bolt at an angle. This helped get the heims in the shocks at a more neutral area so when it starts flexing, I don’t max the heims out (they would max out before I moved the bolt hole).
dbc5f6f956ee3174e8765d680e489e0f.heic
Full flexy flexy oh yes
e9cbf11d9820b55e1f39ae24bed07748.heic
Made some weld in spacers for the upper shock mount so I don’t use 3 stacked up heim spacers used on 2.0 shocks. Then started on the bump stops
Did some CAD, then plugged the design in and burned out the steel with the plasma (card board aided design, my brain/hand, traced some lines with the plasma). Burned in the frame plating and then made some plates for the bump stops. Need to cap the top and then burn it all in.
3c58a81c9996e8a6e32a88fa114dbbee.heic
Already have the other side plating cut, just need to set it all up and burn it in. Feels like I’m getting close, then I look at the list of things to do still lol
5,911
Finished up 99% of the fab work. Leaving 1% cause I’m sure I missed something.
Pass side bump in and plating done
a936fef32ffb623ada9022e85c4f0292.heic
Boxed in the opening in the rocker guards. Still don’t really like it. They may get hacked out all together at some point and also cut some of the body rocker out
90d992f560c2d3b331960a63b5d97c23.heic
Gusset on top of the lower link frame mount. Not tacked in as I need to burn the mount in under the gusset first
5ac97a7a99983af0af1e270de290bba7.heic
Top crossmember setup. I’ll yank everything out before I go putting it in and then clean up the end of the factory tubing. Lots of room though.
75536bb872d75a1e8f0f191417a9e142.heic
7a85bcb69518198a872ddb28eb8dcf6e.heic
6246cd4ad8aa52527ed5f860dddc93f1.heic
I’ll start pulling things apart, weld everything, clean, paint and reinstall.
5,911
Cleaned up the garage, pulled the axle and links, and started welding things up on the frame. Got the lower link mounts and gussets in
70623bd754eaad230591bec645deb359.heic
Upper is 3/4 burned in. I need to unbolt the body and lift one side an inch or so to get the gun in and burn the top in
e14ec6b0f1cd32d88d0cd84d9befd6ae.heic
Top crossmember hoop burned in, plates on rockers burned in and started burning the bumpstops in when I ran out of gas so stopping point for the day.
next day
Frame is all done, just need to weld up the axle mounts. Also got the body jacked up and welded the top of the upper link mount.
f632aed278558d87fe48b9e2e5e2b33f.heic
2d32bd14dca75eaaa9afd27b077d8347.heic
Also had the frame mounts nagging at me. Since the bolt goes up at an angle to hold the shock and keep the heim from binding, the bolt head and nut didn’t fit flush to the mount. So I sleeved each end so the bolt and nut will sit flush and hold torque. Add a little more strength too.
abebdd2b41a58eba3378db50cdb04a24.heic
630765e09d2614a2183c4846e5ad7f6b.heic
My welding on the bottom of something sucked initially. had to change up to pushing the puddle instead of pulling it and get wire speed slowed down but not too much. was kind of a bear as ive not done alot of "upside down" welding. got it figured out eventually. Do need to get some anti splatter for the gas cup and tip, its packing up fast welding all this thick stuff up.
5,911
Thanks guys! im ready to get this thing on the ground and rollin. might have it on its own weight saturday if all goes well.
5,911
Not real sure. Factory frame is white. Probably just go gloss black as that is what the bumpers and rockers are. Will make it easy for the yearly “clean up” which entails of a good pressure wash and repaint lol
5,911
Got the axle welded up and ready Saturday. Bout as far as I got with few buddies from out of town stopping by and a party at fishes.
Today, frame and axle got paint. Nothing special and clearly did not care to tape shit off. Mall crawlers will shun me for this
c148286b442e0d0fbad08b89353084a0.heic
2b9dda3900a655721e1239d7ea067dd5.heic
Then trimmed about 1” off the lower link frame brackets. Way more bracket than I need.
18bb8a1ce768b5686aa3eed374bc246c.heic
And then got the brake lines done on the axle. Not sure if that rubber hose will be long enough but I think it will.
7355a615a3506c4df4330ce9a62084fe.heic
50689ad968d29c820150453f2218a459.heic
At this point, links need paint, need drive shaft, clean up inside of the drums (surface rust), cross fingers that ebrake cables hook up like I think they will, get hardware for shocks, make a few little spacers and put the bitch back together.
