Gonna get rid of my LMM...
KidwickedLMM
Jun 12, 2011
70
Love my 08 but I'm gonna trade/sell it next week. Its still an almost everyday driver and the fuel mileage is seriously the worst I've ever seen. It won't do better than 10.1 mpg no matter how soft I drive it. Averages right at 8mpg just driving normally everyday. I've done everything people have told me to try on it and just can't afford to drive it. I switched to a Duramax because of all my buddies constantly telling me about how much power they make, and how great the mileage is along with it. Haha. I have found one of those statements is very true, however the other couldn't be farther from the truth. Pretty disapoined !:mad:
KidwickedLMM
Jun 12, 2011
70
I have a 5" mbrp straight pipe up to a 7" single stack, so I got rid of the dpf, and egr. We just put plastic caps on the sensors and deleted both with efi. I've tried like 6 or 7 different tunes goin for mpg. Put a dps5 switch on so I'm not always driving around on the biggest tunes.
rcr1978
790
Spring Creek, NV
I'd have to say something is wrong or is getting figured wrong :confused:
My 04 LB7 gets 8-10mpg pulling a 5th wheel trailer and doubles with wheelers or seadoos behind it on tons of passes-rolling hills and I thought that was shitty. 2010 CCLB gets 17-19mpg unloaded cruisin 80 on the highway with a dpf delete, 4" exhaust, and stock tires. So something is either up with your truck or with how it's figured up. Ever check your speedo/odometer against a good gps to see if they are correct?
WTF
slow and broke
Nov 20, 2006
229
Wasco,CA
When was the last time you changed ur fuel filter? And the right tuning is a big thing too
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
This sounds odd...how come you haven't brought up your mileage complaint before? Maybe I missed it, but you obviously have an issue!
delivered via your forum daddy!!
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
My truck is not too far off from yours and I see over 19 most tanks with 60% city.
Not sure who does your tuning but I would talk to them.
Also x2 on the fuel filter when mine needs to be changed my MPG drops fast and smokes more then I like.
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Looks like he did almost a months and one week ago http://www.duramaxdiesels.com/forum/showthread.php?t=33148
Good find, Habit not looking on tapatalk.
Kidwickedlmm, did you ever try another tune? "Big efi" tune doesn't say much. Give these guys a little more info and they might be able to figure out what is going on unless you have already made a deal on another truck.
Either way, good luck
KidwickedLMM
Jun 12, 2011
70
Does how we just shut the dpf and egr off possibly have something to do with it? Like I said we just put plastic caps over the sensors. Ya guys I have calculated it by hand and its even worse than I thought. CTS said I was in the low 12s mpg, and figured on a calculator its closer to 10 mpg and some tanks dips to as low as high 8s. I pretty sure my hottest tune is a 3800pw tune. Also have a 70hp, 120hp, smoke(which I never use), and another hot tune with a different adamazation that smokes harder at wot. I also have an air dog 2 165.
fast03
1,201
60
Rancho Cucamonga
did you actually remove the dpf and straight pipe it or just cap the sensors and turn off the reporting parameters in efi? If you removed DPF and Cat you should be getting pretty good mileage. My bone stock LML is getting 18.5 highway with only 400 miles on the clock.
fast03
1,201
60
Rancho Cucamonga
Is this all you did to get rid of the dpf? if so the canister is probably clogged
