Going back to Folding?
C.C.Reed
May 1, 2008
91
Which 4P motherboard does it have? Arima, Tyan, Supermicro? How is the BIOS setup? Check these settings. You can drop some TPF.
- PowerNow set to Disabled
- NUMA/SRAT set to Enabled
- Node Interleaving set to Disabled
- Bank/channel interleaving set to Auto or Enabled
- Tyan boards - Ungang DCTs set to Always
My Supermicro H8QM3-2 running quad 8431s and the Asus KGPE-D16 with dual 6174s. The Asus pulls less wattage and is a little faster. I have a 4P Tyan S4985 that I could never get stable running the 6-core chips. It's sitting over in the corner. Guess I should buy some 8389s for it.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Thanks!
I've got a SM H8QME-2+ running right now with 8389's (2.9ghz) in it. The 89's are 75watt but have 2200 HT bus, unlike some of the other quad chips. They can be had for $20 each if you haggle.
On Ebay, there are some BIOS dealers that have chips for the Socket 7 mobos. I ordered some.
I bought a Tyan S4985, but can't get it to light even with a single chip. But it was $56.
Also got a Dell quad socket, brand new, for like $75. But it requires a proprietary power supply, it's not ATX or anything else I've seen.
I have a ASUS Dual G34, with Engineering Sample 16 cores x 2.3ghz in it. Not really impressed, and it costs far more than the Junk Bin quads do.
I'm still playing with it.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
The Tyan was the BIOS chip, $30 on Ebay.
Now to populate it.
If anyone needs DDR2 registered ECC RAM let me know. I have surplus.
We did over 1,000,000 point in 24hrs. Congrats all!
C.C.Reed
May 1, 2008
91
What speed is that RAM and how much do you have? Guess I need to find 8 sticks, some eBay heatsinks, and a PSU to get my S4985 up and going again.
Probably just grab a few of these since I have quite a few Noctua fans laying around unless you found better cheaper alternatives for yours. My 8431s don't really put out that much heat so I doubt the 8389s will.
http://www.ebay.com/itm/SuperMicro-...per-heat-pipes-2U-3U-4U-Opteron-/130855257424
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
They are DDR2-667 Registered ECC 2GB.
8 sticks? PM your mailing address if you want some.
Heat sinks are a different issue. If you can find the adapter bars (cheap plastic bar that bolts to the factory hole) you can use any AMD Phenom/Athlon fan/heatsink.
All mine are passive server heatsinks.
Avoid the Dell units. They don't bolt up. They require a special mobo.
The 8389's run cool.
Note:
These are Engineering Sample 3.0ghz 83xx quads:
http://www.ebay.com/itm/120961411777?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
He wants too much. I did buy 4 to test.
EDIT: Confirmed 8391? Quad, but appear to be SE chips, which run hotter.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Ghetto Master 5000! Errr... 4985.
Junk Ebay parts thrown on a desk, started with a screwdriver. Drives are in the desk drawer.
Fans are $4 NewEgg specials just sitting on top of the heatsinks. 52 deg C when folding.
Burning it in on SMP and I will see if it folds Big.
