Would the snap on equivalent of the tech 2 take care of resetting the taps or does it have to be a tech 2?
I don't believe that is the one I am running. I have an os out of an 05 so that I can run the OD/LO. I would appreciate if you would send me that one to try. PM sent.What TCM OS are you running? If it is anything other than 15172881 then that is most likely your issue. There is a TSB out regarding the 2-1 downshift clunk and this is the OS to correct it(it is also the OS with OD/LO). I have it if you neeed it.
I would like it also and have the same problem, never knew there was a fix for it pretty much just accepted it as another built tranny problem because I don't remember it being there stock.
Yeah my downshifts are better, no more clunk after stopping. Engage seems slight smother after all. OD/LO work fine on the new tune. Now I just need to figure out my TCC lock up speed in 5th as I like it lower than stock but, I think I got it too low as now it will bark my turbo occasionally when it locks. thanks ferm:hug:
It is necessary. In fact using the Fast Learn with the Tech 2 is a real plus. Without doing this your Alli may never be all it can.
Thanks Mike, I'll have to get the efi out and start playing, unless someone knows of someone in Aus with a tech 2, lol. Anyone?
Is there a GM dealer in your area? Around here, you can get them to do a diagnostic with the Tech 2 for about $100.00 US.
Dont stress Bryan,
I am looking at buying one. Feel free to chip in some money if you like. haha
I done your with efilive, but as mikeL said not the best.
Is it still shifting Funny?
Cheers Heath
