GM Specs section suggestion
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Would it be possible to reorganize the GM specs threads by putting them into sub forums? The current one could be for general information, then have one for LB7, LLY, LBZ, etc? I think it'd be easier to look for specific info for your particular motor instead of having them all mixed up.
Just an idea.:hug::D
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
I could do that. But, what would we do with the ones that include all model years?
ripmf666
15,123
14
47
Wentzville Mo
speaking of specs, did you get anywhere on the crank bolts henry?
I will check that this week they specs are all over the place with the years. I will see if they added the 2nd part number like they had before or if they still have 1 number. If its 1 number we will have to go buy the specs for each year truck and I will swap in all the new specs if they changed from what is posted now.
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
I will go and redo the model years and update the specs after you set up the sub folders.
I got them set up..... You want some help moving them? I moved a couple to see if I set the forums up correctly.
durallymax
Apr 26, 2008
2,756
Under The Hood
:thumb::thumb:
ripmf666
15,123
14
47
Wentzville Mo
If you want Kat then I will log in to Gm service info and look up the history and if its updated I will edit the post that need it. :hug:
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
OK... I moved the ones I could. Like I said I don't know where to put the ones I left. Since they apply to several model years.
wildwolfproducts
May 31, 2011
46
Is there a section that shows the ratings for all of our trucks? Like my 2500HD Crewcab 4x4 Duramax short bed? What are the tow weights for bumper and 5th wheel? I have a class 5 2.5" hitch on mine also. And other add-ons that I know does not up the factory ratings. Like air bags and 19.5 wheels and tires. I now haul a slide in truck camper with a slideout that weights around 4000 lbs. But were planning on selling it and buying a 5th wheel camper. And not sure what the factory ratings are on it for towing a 5th wheel.
Pete
