Has anyone used gmgaugeguy.com in Glendale, Az to get their instrument cluster redone? If so, would you recommend using them?
I know they are not a vendor, but I have had good luck with my 04 cluster from USSpeedo. Fast and relatively cheap. Upgraded the cluster light for while they had it. I think I only paid for the led's. In and out same day they received it.
I'm a a usspeedo dealer.
http://creaturesofthenightperforman...0-3500-AUTO-Replacement-cluster-P2444353.aspx
Ive had a gm gauge guy led conversion for almost two years,and no problems. He is local to me so it makes it a little easier. I had a dark blue at first and switched to a light blue because the dark blue was very very bright. The dimmer wouldnt dim enough and with the dimmer turned up it would almost light up the whole cab. Since I had them swap bulbs its been a lot better and no hotspots.
There was a very bad review of them on DP recently.
Hey how's it goin, I had multiple clusters from us speedo go bad,the last one the lighting was terrible...I purchased a aqua blue gauge face w/ the last cluster,but I just wasn't happy w/ the lighting it had some dark spots & looked kinda cheesy
