Please read this TSB:
http://www.duramaxdiesels.com/forum/showthread.php?t=8669
Quote:If a vehicle comes in for service for a driveability/powertrain concern as a result of a Power-Up Kit installation, the dealership technician now can read the last 10 engine calibration part numbers and CVN history using a Tech 2®.
The dealership technician would input each ECM calibration part number into the SPS/TIS2WEB CVN database to confirm the CVN history information. Refer to Tech 2® path table in this bulletin to verify ECM calibration.2007-2009 LMM Tech 2 Powertrain Output Controls Path Table for NON-GM ECM Calibration
does this TSB state that they can tell you had a tune in it even if you put the stock tune back in?
I have had alot of trans problems, with no luck from the dealer, and finally resorted to doing things myself, after weeks of it sitting at the dealer
I used my efi live to try and manipulate my TCM, as it wouldn't shift into 6th gear until 2500 rpm in 5th, even at part throttle...
I put the stock TCM tune back in.
Can they tell I had flashed it, even if the stock tune is back in it?
What about the ECM?
Thanks
also :
http://www.duramaxdiesels.com/forum/showthread.php?t=16006
They have a nw TSB telling the dealers not to warrant diagnosis time to drivability issues with trucks having tires other than the stock size.
My beef with this is they can blame any irrelevant TCM or TC issue on my tires?
WTF???????
What about the ECM?
Thanks
also :
WTF???????
