Gm brand gasket maker
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Just wondering how long this stuff takes to cure up enough to fill the motor with oil. Hoping to start this truck as soon as I get it in the truck. I'd usually wait about a day. Finally got the engine hoist out where I can use it and just need to bolt the rear adapter and lower pan on and its ready to install.
Sent from my PC36100 using Tapatalk
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Yes. I'm hoping the time it takes to get the engine in the truck and everything else hooked up would be long enough to cure.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I know I can fill it with oil, wondering if I should wait 24 hours before it gets oil pressure though. The gm black silicone I have here says it needs that long to fully cure but the grey kind doesn't say anything.
Darius6t9
I'm the Floater. Lurking.
Aug 23, 2008
574
Rusk, Tx. Again
At the nissan dealership where I work, we use some grey stuff for the timing covers and oil pans. As soon as we are done, we start it up and send it out. Haven't had a single issue yet from any of them. And I see them come back all the time for their oil changes. No leaks. Should be safe for you as well.
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
i absolutely love 1194 liquid gasket this stuff never gave me a prob with anything ive ever used it on seals up pretty dam good and real easy to work with:thumb:untitled.png
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
the GM grey stuff is good, i like using the oem stuff. we put on intake runnners, had problems the next day with the heads and had to remove them and it seemed like it was still tacky in the middle. I imagine you could run it as soon as you used the silicone with no problems but im with you on waiting a bit t let it cure.
durallymax
Apr 26, 2008
2,756
Under The Hood
I always use the right stuff. It says its ready to return to service in one minute. Never had an issue with leaks.
As for the GM stuff, I'd say your fine. The dealers aren't waiting long to return the vehicles. The assembly plant probably isn't waiting long between installing the stuff and hot testing.
