Gas pedal shake when rpm's are high
Theriot
Oct 20, 2013
La
When my truck is about to shift into the next gear and the rpm's are high then it starts to shake the gas pedal any ideas what could be causing this problem?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
thats physically impossible for the pedal to shake itself. The accelerator pedal is nothing more than two potentiometers with 5 volts going into it.
It must be the firewall is vibrating or something and you are just feeling it through the accelerator pedal, because the pedal is bolted to the firewall.
Ben
