Garage area software upgrades now with fuel images for your signature
Poltergeist
Ghost in the Machine
Aug 1, 2006
29,563
Ontario, Calif.
www.poltergeist.us
I just finished upgrading the software for the Timeslips/Garage area. The front layout is different now. One of the new options in the garage is that you can now track your fuel usage. By inputting the amount you bought, the $ cost, the starting and ending mileage the garage will give you totals and averages for mpg etc.
Let me know if anyone has any problems.
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
Is there a way to add in a gal to liter converter and CAN to USD converter for the ones in Canada and km/h too?
I know I am asking a bit but i know you are that good.
Poltergeist
Aug 1, 2006
29,563
Ontario, Calif.
www.poltergeist.us
If you goto "EDIT VEHICLE", whatever you select as the type of mileage (miles or KMs), purchase price (dollars, pounds, euros, etc), and fuel preference (litres, gallons, etc) will then change what is shown in their fuel tracking stats.
Poltergeist
Aug 1, 2006
29,563
Ontario, Calif.
www.poltergeist.us
Like I said previously in this thread the garage can track you fuel usage and give you averages, totals, mpg etc. Also you can have an image in your signature for this now.
Once you have started putting in your fuel usage you select "Generate Fuel Signature Image" from the pull down.
attachment.php
From there you select which of the 4 images you want to use (red circle):
attachment.php
Below are the 4 images you can select from.
Copy and past the link (green circle) into your signature in the UserCP and add the img tags like the example below. As you update your fuel usage your sig will update. Also you can use the image on other sites for your sig not just here.
PHP:
[img]http://www.duramaxdiesels.com/forum/stats.png?id=454&type=1[/img]
SmokeShow
6,818
Lawrenceburg, KY
so if we got up to 60 entries, would it trunk off the last one for each new one we input or tell us we can't enter anymore in? I keep a spreadsheet of mine, I could easily date it back and have twice as many entries. :D Or just start with 2010 numbers and go from there.
This is awesome. :thumb:
Poltergeist
Aug 1, 2006
29,563
Ontario, Calif.
www.poltergeist.us
I've bumped the limit up to unlimited. So have fun. :thumb:
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
any way to edit them as I put it in as liters but must have still had it set to gal and when I changed it. It is all messed up.
should be around 12L/100km and $72.50
SmokeShow
6,818
Lawrenceburg, KY
got my going... just started with this year... not ambitious enough to go back any further than that. :angel:
wish it would show at least one decimal point instead of rounding to the nearest whole number on the MPG. :D
Dozerboy
4,896
473
TX of course
I don't think its working
When I go to Generate Fuel Signature Image it looks fine, but its blank after I add it. And it goes to L/km instead of MPG.
