So i have about 6k miles on this engine and its been running great. i drive it mostly in the tow tune with my slide-in camper on the truck and no issues. its been sitting for 3 weeks and i took it to run a few errands, made 4 stops and then home. park it and head inside, all normal. i happen to come outside to grab a kids toy and hear the lift pump running, WTH? I cycled the ignition to wake the computer up and hopefully fix itself. doesn't work so i tried stating it and nothing, dash lights come on and look normal but when turned to crank its just crickets. thinking maybe batt. is dead i grab the trickle charger and pop the hood, and the burning electrical smell hits me. lift pump is still singing so i pull the fuse on power wire from batt. to pump and it stops. neither of the fuses in the add-a-fuse are blown, in-fact i cant find any blown fuses. i pulled the fuse panel off to reveal the melted connectors underneath. after all the excitement i noticed the wipers were up like i shut it off mid wipe, but i hadn't used the wipers. aside from that everything else seems normal.
so aside from tracking down new parts and replacing some wires i want to track down the cause. the lift pump trigger wire with the add-a-fuse has a 3amp fuse and seems unlikely to cause this. could a bug or something crawl up inside the board and cause something like this? if something was shorted or backflowing seems fuses would blow? any help with locating parts or cause would be great. thanks
