Fuel test port removal.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Posted this on df with no replies.
Just wanting to get a little statistic here. Those of you who tapped into the fuel line through the test port or schrader valve for a pressure gauge.... Did you end up snapping the aluminum shaft off, or successfully unscrew it? I've snapped one. Now I have a new one on the motor and I'm almost scared to try again lol. Do you think I can?
rgullett83
1,607
Illinois
I have broken two of them, after that I used a small propane torch, havent had an issue since
Sent from my GT-I9300 using Tapatalk 2
408.Luke
Joined the DARKSIDE
Sep 19, 2009
432
Houston
If the valve itself is leaking you can replace just the valve or take the valve off and cap it. But like previously said, its easy to break the fitting off the block
B1 596
Dmax rods cost how much..
Apr 30, 2010
52
Hudson N.H.
So if i take it off to cap it is it a standard pipe thread or something special ? Just wanna get what i need before I take it apart .
408.Luke
Joined the DARKSIDE
Sep 19, 2009
432
Houston
Not sure what the thread is, ace hardware by my house did have something that fit it, just dont remeber what it was.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I just ordered a adapter fitting from all season diesel. I'll try it with a torch. Last time I just ran a machine screw down in it after it broke for about 6 months lol.
Sent from my PC36100 using Tapatalk 2
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Don't most people remove the restrictive test port block and run fuel line directly from filter head to CP3? At least on the LB7.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I don't see how that will really be any less restrictive. I know a lot of people do that. But you still have the restriction of the orfice on the cp3 inlet fitting.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I want a gauge as close as 6 inches to the cp3 inlet as possible. But don't want a sensor in a soft line. So this is the happy medium for me.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
For sure i swsear that little fitting is only like 1/4 i ditched mine long ago.
Thats why i buy the big 1/2 inch and 3/8ths parker fitting and drill them out just a touch.:D
The best thing you can do is run 1/2 inch rubber fuel line right from your lift pump to a fuel block in the motor compartment somewhere,mine just floats right behind the 2nd cp3,i used the summit or jegs blue anodized fuel block 1/2 inch in and 2 3/8ths out and its taped for 1/8th inch pipe thread in the top of it where i installed a 0 to 30 psi fuel gauge then run 3/8ths to each cp3 where i have the 3/8s parker fittings.I have no problems with fuel delivery. PM me you # and ill text you some pics of my set up.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Thanks I always like pics! I plan on doing that next year. This year I have enough stuff to get done before the real season kicks off!
