Fuel System !
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Trent, you probably know, but ground one of the filler neck bolts to the frame. The tech guys have a field day with that one.
Looks awesome. I'm starting to get a bit worried...:D
Good to know Rob and yes be afraid:D
I like those donaldson filters nice and big! They should work well.
Are you going to worry about you fuel gauge?
Looks clean Trent and Im glad you got the parts for the motor
RickDLance
1,276
14
Is the picture misleading, or do you have the sump pointing to the front of the truck?
That won't work. ;)
SmokeShow
6,818
Lawrenceburg, KY
just be sure you have a couple feet of extra in your lines so that when you need to flip it around, the hose can reach the new length. :D
For something as simple as just flipping it around so the fuel is sloshed into the sump rather than slung out of it on launch, why not just do that now instead of trying to see if it's going to be a problem or not? Just set it up now so that it for sure won't be a problem. Is there some reason why you can't or don't want to turn it around now? something in the way? or just being stubborn? :D
Just wondering.
Also, what make and model are those pumps? Still running one to each CP3 like you mentioned before?
C-ya
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Just wondering.
C-ya
Maybe stubborn i guess :angel: I just dont think it will be an issue , and soft hose is so simple to change and the mounting as well , I would like to keep it the way it is for the pluming design I have envisioned i guess and i if wont work I wont complain about changing what i want it too look like :D I know a few guys running the Helman unit facing forward with out issues and its pretty much the same design , like i said I see it as a 20 min fix to change so no biggie either way .
13,765
834
As long as you don't run the fuel level too low, you should be fine.
SmokeShow
6,818
Lawrenceburg, KY
He admitted his reason is stubborness and aesthetics - wants hose routing to look a certain way. Fair enough to me n even though his configuration isn't optimumit should work alright if enough fuel is in the tank n it's the way he wants it. Nuff said IMO beings it's his project. :D
Cya
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Why go against the laws of physics if you don't have too. ;)
Simplicity and reality stepped in and took out the the laws of physics.
There is a new sherrif in town and his name is Trent:D
Agrree that it would be better to have the outlet and pumps at the back ,but it isnt needed. I had no issues at all and Trent will be pumping more fuel than I was and yet burning close to the same amount. Keep the suction line to the pump and keep the tank as full as possible he will be fine.
I would maybe consider using check valve on the outlet of the fuel cell though.
coldLBZ
Apr 22, 2007
2,344
Alberta, Canada
Trent, please correct me if I'm wrong. Mitch I believe those are BD Flow Max pumps. 150 GPH at 10psi, 165 GPH full flow. It is a gerotor design. The P/N is 1050320 for a 01-07 DMax. I just happened to have a BD catalog here with me. BTW Trent, the set up looks awesome.
TrentNell
Jul 7, 2008
7,543
slc tuah
Yep they are BD's "Flow Max" lift pumps and the filter setups are BD also .
maine04max
Dec 11, 2008
1,009
Nice job Trent . I cant believe how far you have come in such a short time ,,, keep up the good work and should be a great set up :cool:
